ONEX #54 Web Site
ONEX
F09, P04, L02
Install firewall, engine mount, nose gear
Final installation/riveting of the firewall and associated pulley brackets, hinges and battery box.
Installed the engine and nose gear mount. Installed the nose gear.
Torqued all the firewall bolts/screws, applied torque seal where appropriate.
Installed cotter pins in nose gear linkeage forward of the firewall.
Greased the nose gear bushings using the grease fittings.
Firewall installed
Motor and nose gear mounts installed
ONEX Home
1326
Basic Information
Certification
Finish and paint
Flight testing
Fuel
Systems
Trips
458
